Activity Forums Apple Final Cut Pro Titles in SD project
  • Titles in SD project
    Posted by Jonathan White on November 13, 2011 at 5:58 pm
    For the first time I’m working with SD footage in FCP X… when I insert a title it renders out very pixellated… not sure what to do? Is this a bug?
    Johnny
    Seanchas Productions, Galway, Ireland
    Jonathan White replied 14 years, 10 months ago 2 Members · 3 Replies
  • Jonathan White
    November 13, 2011 at 7:51 pm
    Well to answer my own question… I changed project properties from 25i to 25p and that sorted it… does this mean that titles don’t work with interlaced footage??
    j.
  • Oliver Peters
    November 13, 2011 at 9:47 pm
    [Jonathan White] “does this mean that titles don’t work with interlaced footage”
    They should be fine. I’ve been working in an interlaced project and that wasn’t an issue. Are you monitoring “both fields”in the viewer (and at 100%) and do you have the prefs set to “best quality” rather than “best performance”?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Jonathan White
    November 14, 2011 at 11:26 am
    Show both fields… that was it 🙂 Been a while since I worked with interlaced…thanks.
    j.
