Activity › Forums › Apple Final Cut Pro › Titles corrupting in edit on reopening project
  • Steve Connor
    April 2, 2012 at 7:42 pm
    [Simon Ubsdell] “I don’t see why you would want to use this rather than using the Share/Export Media option to make a ProRes master protection copy. “
    I use the share/export media function all the time to make backup files of my current project as it progresses, I then delete earlier versions as I go. It works well because it’s much quicker than any mp4 export and as you say the quality is better
    Steve Connor
    “FCPX Professional”
    Adrenalin Television
  • Simon Ubsdell
    April 2, 2012 at 8:09 pm
    [Steve Connor] “it’s much quicker than any mp4 export”
    As you say, it’s much faster – very fast indeed actually. It’s here that you can see the power really kicking in.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Bill Davis
    April 2, 2012 at 9:15 pm
    [Simon Ubsdell] “Not really any doubt about it. This is not, repeat not, a mastering format as I am sure you are aware.
    Simon Ubsdell
    https://www.tokyo-uk.com“
    Yes, we agree.
    It’s not a “mastering” format. But it’s still very useful – particularly in the connected world of X.
    This function is precisely what the OP asked about. A sharing version that can be trusted to be the same every time you access it, no matter whether the original media is present or not.
    Which is exactly what I think he was looking for. Unless I mistook his intent.
    For the lurkers, again, I agree with Simon here. If your intent is to make a MASTER file for final output – then you should go to the Export Media function (control E.) and create a formal master with the compression you prefer.
    But if you’re intent is to share progress states of your work – and if you’re having problems because you’re storage or workflow is such that you like to move projects on and off-line for capacity management purposes – or if you’re having problems with project elements “shifting” or substituting out for whatever reason – then the new FCP-X Media Browser joins e-Mail share and the links to YouTube and Vimeo as fast client proofing options that are pretty flexible in X and that we didn’t have in Legacy.
    Nothing more than that.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
Page 2 of 2
