Activity Forums Apple Final Cut Pro Titles bug?
  • Titles bug?
    Posted by Ray Wang on August 19, 2011 at 10:17 am
    Steps followed:
    1) Put clip on primary storyline (640×480 30p)
    2) Added “Torn Edge” title
    3) Typed text for both text lines
    4) Render All
    After rendering, I am unable to change the text. The text box even disappears from the inspector. This does not happen with other text / lower thirds.
    Does anyone have the same issue?
    Also I have found the UI to be quite jerky when adding / editing text / lower thirds. It would take 1 – 2 seconds to click into text or move the text box around.
    I am running this on 2010 MBP with 8Gb ram/512Gb SSD
    Ray
    Ray Wang replied 15 years ago 2 Members · 2 Replies
  • Tom Wolsky
    August 19, 2011 at 10:54 am
    Torn Edges doesn’t have a text box at the top of its text window because you can only have the two lines of text. There is no need for a box for multiple lines of text. After rendering I can change the text in the Viewer without problem. I’m not having a problem with it.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Ray Wang
    August 19, 2011 at 11:18 am
    Something may be wrong with my project. I deleted and recreated the title but same issue of not being able to re-edit the text after rendering. Also from time to time I find texts un-rendered.
    In my short 40 seconds storyline, I have about 10 custom texts, 5 shapes (custom motion template). Nothing complicated but as I edit / re-edit, I nothing some strange things. I will try to delete the render cache and see what happens.
    I have a typewriter text with English and Japanese characters. Re-editing the text makes the last character (Japanese) pop up first followed by English text (left to right). Hmm..
    Update: after deleting the rendered files and re-render, the bug went away.
    Ray
