Activity Forums VEGAS Pro Titles are not there !!
  • Titles are not there !!
    Posted by Martin Phillips on May 7, 2009 at 7:49 am
    Hi all,
    Ive just added 3 titles to the top video track – the first one is fine and can be seen as i scub through, the next 2 (whilst they are there on the timeline) are not in the preview window as i play or scrub through..
    I am new to Vegas, and i guess it will someting silly – but its got me stumped…
    Thanks… Martin
    Martin Phillips replied 17 years, 3 months ago 2 Members · 3 Replies
  • Martin Phillips
    May 7, 2009 at 7:57 am
    I think i have the answer – for some reason track motion was taking all the added titles after the first one off to the left outside the viewing area…. still not sure why, but sorted now.
    Martin
  • John Gordon
    May 7, 2009 at 3:36 pm
    track motion worked the way it was supposed to. You key framed movement at the first title. you would need to set a “reset” keyframe before you arrived at the next title event and then keyframe the desired movement at the appropriate timeline location, then “reset” and repeat for the third event. I would just use pan/crop on each event unless you like messing around with movement on the track level.
    hope this helps.
    John
    John Gordon
  • Martin Phillips
    May 7, 2009 at 5:00 pm
    Thank you. I will.
    Regards
    Martin.
