  • Posted by Richard Hutt on August 11, 2010 at 2:36 pm
    Is there a reason that CS4 ppro title tool does not keep attributes of titles when using “new Title Based on Current Title”? It seems to be with the leading and the kerning properties. Is there another button i need to turn on/off?
    And does anybody know a website/help forum that would have more advance tutorials for CS4 Ppro? Adobe Tv and creative cow have primarily basic info, btu i have so many other questions that the tutorials dont answer I am a recent AVID transfer and would like to find some shortcuts.
    thanks
    Tim Kolb replied 16 years, 1 month ago 3 Members · 10 Replies
  • 10 Replies
  • Tim Kolb
    August 12, 2010 at 3:09 am
    How does it not save the attributes…it saves the whole title…does it not?
    I think I’m not understanding something completely here…
    Can you tell me what is happening that indicates this?
    TimK,
    Director, Consultant
    Kolb Productions,
  • Richard Hutt
    August 12, 2010 at 12:17 pm
    Hey Rob
    thanks for the reply. heres the deal. I go into the Title Tool and type up an information board with several lines of text. I add some kearning and leading to make it look good and fit on the page. Its automatically saved in ppro. Then when I want to type up my next info board, I click the button “New Title Based on Current Title” so I can use the same attributes form one board to the next. However when i start typing, all attributes remain the same except for the kerning and the leading, they revert back to default and I have to reset them.
    Hope that explains it.
    Any clue on other instruction tutorials or wensites i can vist for help with premiere other than COW and Adobe TV?
    I appreciate your help with this.
    Richard Hutt
    Producer/Direcotr
    WCTV
    Chesapeake, Virginia
  • Richard Hutt
    August 12, 2010 at 12:18 pm
    Hey Tim
    thanks for the reply. heres the deal. I go into the Title Tool and type up an information board with several lines of text. I add some kearning and leading to make it look good and fit on the page. Its automatically saved in ppro. Then when I want to type up my next info board, I click the button “New Title Based on Current Title” so I can use the same attributes form one board to the next. However when i start typing, all attributes remain the same except for the kerning and the leading, they revert back to default and I have to redo
  • Tim Kolb
    August 12, 2010 at 12:45 pm
    Are you deleting the existing text object and dragging out a new box or typing over the text that has the attributes already assigned?
    TimK,
    Kolb Productions,
  • John Frey
    August 12, 2010 at 3:28 pm
    lynda.com
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
  • Richard Hutt
    August 12, 2010 at 4:01 pm
    Thanks John I should have included them in my original post. They have great stuff, unfortunately my bossed wont buy us access and our free demos have run out. But thanks for the info.
    2 production companies…..u b a busy man !
    R
  • Richard Hutt
    August 12, 2010 at 4:25 pm
    Hilighting the text with the mouse then typing over it
  • Tim Kolb
    August 12, 2010 at 11:30 pm
    Are you kerning letter-by-letter?
    I’m not sure an empty text object (which is what you start with when you type that first key after selecting the text) can hang on to kerning info… I guess I never noticed…
    Does the kerning value change in the panel to the right?
    TimK,
    Kolb Productions,
  • Richard Hutt
    August 13, 2010 at 3:47 pm
    The kerning value does change in the panel on the right – back to 0
    the leading actually stays the same When i kern its all 4 lines at the same time
    Maybe its a bug of this software CS4 It does make it difficult to create multi page info boards and have all the text line up the same as I cut to each one.
  • Tim Kolb
    August 13, 2010 at 10:32 pm
    [Richard Hutt] “Maybe its a bug of this software CS4 It does make it difficult to create multi page info boards and have all the text line up the same as I cut to each one.”
    I doubt it’s a bug…it’s just likely the way it’s designed…kerning probably attaches to characters and kerning probably attaches to the text object (box).
    I can’t say that I’ve ever had this happen or not, though I rarely do text graphics where I’m cramming lots and lots of text onto a screen…I tend to do titles and lower thirds, so it’s just possible that not many people have flagged it before…
    Adobe has a feature submission form:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    You could always mention it… most things change when enough people flag them as needing changing.
    TimK,
    Kolb Productions,
