  • Posted by Rap on September 17, 2006 at 7:21 am
    hello
    i did some titles (subtitling) and after rendering and while printing to tape I noticed that every time a title appears the video underneath it gets crappy the movement is a bit slower and the quality looks different, till the title goes and the video looks back the same!! I don
    Erik Pontius replied 20 years ago 3 Members · 4 Replies
  • Grinner Hester
    September 17, 2006 at 2:29 pm
    check your media settings. If your doing a 1:1 project and rendering at DV25, you’ll see it.
    Also, make sure you render and audio dissolves in that same area. I have noticed playpack hooha from what I guess it sees as unrendered effects.
  • Rap
    September 17, 2006 at 5:27 pm
    there is nothing to render, my video is DV25 and the titles are 1:1, and my quality button set to green-green
  • Grinner Hester
    September 17, 2006 at 7:50 pm
    If your are making the final piece, not offlining it, you could try just making a video mixdown over that section. It kills lots bugs but is a major no no for off lining.
  • Erik Pontius
    September 17, 2006 at 10:54 pm
    I’ve seen similiar kinds of wierdness when mixing resolutions. You might have better luck if your titles were DV25 as well and your effect aperture set at DV25 as well.
    Erik
