Activity › Forums › Adobe Premiere Pro › Titler – reversioning issue
  • Titler – reversioning issue
    Posted by James Martin on July 10, 2013 at 1:48 pm
    I’ve recently switched to PP, and have a problem I’m struggling to work around. I create countless versions of the sane movies with different language subtitles. My old FCP workflow was to dupe my english language sequence, and paste the foreign copy into the existing subs. But that won’t work with PP as it would change all the subs in all the sequences to the same thing.
    Is there an easier way than duplicating each title clip, changing the copy, and dragging it into a new the sequence in place of the original subs? That seem a little inefficient…
    Cheers,
    James
    James Martin replied 13 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Ivan Myles
    July 10, 2013 at 3:04 pm
    Separate the common and dedicated clips into different tracks. Create unique titles and subtitles for each language, and place them on the dedicated tracks. When it is time to export, turn the tracks on and off as required.
    For example, the timeline might look like this:
    V9: Spanish subtitles
    V8: English subtitles
    V7: Spanish titles
    V6: English titles
    V5: Common video
    V4: Common video
    V3: Common video
    V2: Common video
    V1: Common video
    A1: Common audio
    A2: Common audio
    A3: Common audio
    A4: Common audio
    A5: Common audio
    A6: English audio 1
    A7: English audio 2
    A8: Spanish audio 1
    A9: Spanish audio 2
    When exporting, enable all common audio and video tracks, and turn on the dedicated tracks as required. If there are too many languages to put on the same timeline, keep the common audio and video on your main sequence and embed it into dedicated sequences for each language.
  • James Martin
    July 10, 2013 at 3:58 pm
    Thanks, that’s actually what I’m doing at the moment, but it doesn’t avoid having to duplicate and relabel every subtitle clip. What I’m hoping to achieve is something as simple as in FCP where I dupe and relabel the sequence before pasting my new language copy into the clips.
    I’s also quite like to be able to stay flexible and be able to make picture tweaks to language/market versions as needed.
    Any ideas?
  • Alex Udell
    July 10, 2013 at 4:17 pm
    Hi….
    How about this?
    Do the subtitles as PSD’s and edit with them into the seq
    Do the PPro project as English Master
    Dupe it and make the Dupe the next Project the Spanish Master
    then if you make Spanish language equivalent PSD’s
    you can relink the Spanish project Subtitle PSD files and they will all be updated in the timeline automatically…
    You can even have the english and spanish PSD’s with the same file names at the OS level to aid in quick relinking…JUST BE SURE TO PUT THEM IN THEIR OWN FOLDER….
    See where I am going?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Jeff Pulera
    July 10, 2013 at 6:42 pm
    Hi James,
    Not sure if this will help you, but here goes.
    So you complete the English version, then you copy/paste edits to a new Sequence, and that will be modified into the Spanish version. In the Sequence, double-click on a title to open it in Adobe Titler. There’s a button at upper left to make a new copy of the title, this will be the Spanish version. Update text and exit back to Premiere.
    Right-click (may be different on Mac) title in Sequence, and choose “Replace with Clip from Bin”. This will take the Spanish title that you just created, and put it in place of the current English title. The placement, timing, fades, etc. all remain intact! Not sure what would be any simpler/faster, I use this often. And of course does not affect titles in the English version, just make sure to hit the button to duplicate the title – sometimes I forget and then I am changing the original!
    Jeff Pulera
    Safe Harbor Computers
  • Walter Soyka
    July 10, 2013 at 7:16 pm
    If you are on Premiere Pro CC, the latest version, released just a couple hours ago, adds a new feature for creating new titles by alt-dragging to a new track on the timeline.
    After you duplicate your sequence, if you have all your titles on a single track, you can multi-select them, alt-drag up, and get a new set. Delete the old set and edit away on the new, independent set.
    Walter Soyka
  • James Martin
    July 11, 2013 at 8:16 am
    Not a bad idea, thanks Alex.
  • James Martin
    July 11, 2013 at 8:18 am
    Jeff, I think this is the kind of thing I was hoping for. I’ll fire up the project and take a look – thank you.
