Activity Forums VEGAS Pro Titler Pro 1.0 & Titler Pro 2.0 Updates
  • Titler Pro 1.0 & Titler Pro 2.0 Updates
    Posted by Roger Bansemer on December 20, 2013 at 3:55 pm
    Is this the titler that comes with Vegas? The one that crashes my system almost every time?
    They just sent out an update and although it gives the URL where you can find the update it says you can also download it directly from the plugin which doesn’t seem to be there to find.
    Any suggestions on this update?
    Roger Bansemer – PaintingAndTravel.com
    Roger Bansemer replied 12 years, 8 months ago 3 Members · 3 Replies
  • Norman Black
    December 20, 2013 at 4:17 pm
    Titler Pro 1.0 is what is bundled with Vegas. 2.0 is a newer version with more features.
    NewBlue changed Titler Pro 1.0 and 2.0 to operate in a separate process to help deal with GPU conflicts between Vegas GPU use and their GPU use on the timeline. So if you had problems before, maybe it will be more compatible now. That is what the big deal is with this new update.
  • Edward Troxel
    December 20, 2013 at 4:51 pm
    For the bundled Titler Pro 1, just download this newest build:
    https://www.newbluefx.com/downloads/Windows/NewBlueTitlerProForWindowsSetup10-131217.exe
    When installing, uncheck all video editor options and then check only the “Sony Vegas Pro OpenFX 64-bit” option unless you are using the 32-bit version of Vegas Pro 11 in which case you would choose the “Sony Vegas Pro OpenFX” option.
    Edward Troxel
  • Roger Bansemer
    December 20, 2013 at 4:52 pm
    Thanks guys.
    Roger
