Activity Forums Adobe Premiere Pro Titler performance SUPER slow, RED project
  • Titler performance SUPER slow, RED project
    Posted by Brian Sarfatty on September 14, 2012 at 4:35 pm
    Working in RED 2K project. Have gotten good performance knocking down resolution in the source and record monitors. But the Titler is SUPER slow, I mean unbearably. I type, a word, and maybe five seconds occur before it appears on screen. Moving text around is super laggy as well. I think the issue is the 2K project resolution. Any way to turn down the preview / paused resolution in the titler to like 1/8th like you can in the source/record monitors? Any other way to boost performance in this tool?
    Don’t want to go to Photoshop because there’s a billion of these super simple lower-thirds, and the client will be changing these through revision rounds.
    Dennis Radeke replied 13 years, 11 months ago 2 Members · 5 Replies
  • Dennis Radeke
    September 14, 2012 at 5:28 pm
    Can you try to see if Photoshop has the same performance problems as you’re experiencing in the Premiere Pro titler?
  • Brian Sarfatty
    September 14, 2012 at 6:22 pm
    How do I get the title into Photoshop from Premiere? I know there is a way, just don’t understand how yet, new to software. Also, again, want to avoid doing titles in third party app.
    I did try making titles in a 1024 HD project, and the performance was much better.
    I then tried forcing the size of titles to be 1920×1024, and then dropping them into my 4k sequence. Did not go well. Had to resize, then hard to line up, looked pixely….
  • Dennis Radeke
    September 14, 2012 at 7:18 pm
    Hey Brian,
    File>New>Photoshop file is all you need. 😉
  • Brian Sarfatty
    September 17, 2012 at 9:25 pm
    Photoshop seems to be able to handle working at 4K resolution just fine. Have not noticed a huge lag. Just within Premiere. But again, there’s so many of these simple supers, I don’t want to get into making them all in Photoshop.
    I am having other performance issues, mainly with the split screens that come up doing certain types of trims. See:
    https://forums.creativecow.net/readpost/3/930579
  • Dennis Radeke
    September 18, 2012 at 1:11 pm
    If you’re comfortable with Photoshop, then use it. To get around the pain of making the super each time, I’d do the following:
    1 – create your super in PSD and flatten it as necessary, keep Photoshop open and the PSD open.
    2 – Create new PSD in Premiere Pro. It will open a blank document.
    3 – drag your psd title into the blank one.
    4 – finish and save.
    Hope this helps.
