Activity › Forums › Adobe Premiere Pro › Titler crashes when DV deck connected
Posted by Dave Baldwin on September 15, 2006 at 10:40 pmHaving an intermittent problem where when we open the title tool or try to edit an already created title the system often crashes. It doesn
Dave Baldwin replied 19 years, 11 months ago 3 Members · 5 Replies -
Dave Baldwin
September 15, 2006 at 10:43 pmCLARIFICATION: PPro crashes, not the entire computer system. We just need to restart PPro to get back up and running, but of course any unsaved changes are lost.
Vince Becquiot
September 15, 2006 at 11:13 pmWell that begs the question, why disconnect it 😉
Indeed, Premiere uses the firewire at all times to preview video through the deck as well if you use a monitor, so disconnecting in while Premiere is running at all is asking for problems. You may want to check if that is happening if you disable the DV out in Premiere Preferences.
Vince
Vince Becquiot
September 15, 2006 at 11:16 pmMy apologies, I misread your post title and was looking a the second thread.
I’ll let others answer that.
Vince
Craig Howard
September 16, 2006 at 1:12 amTry changing your playback setting to Compatible (not GPU Accelerated).
Craig Howard
Shooter Film Company
Auckland
New ZealandPremiere Pro 2.0
Dave Baldwin
September 18, 2006 at 3:39 pmThanks, Craig. I think your suggestion stopped the bleeding, but it’s still frustrating because it was working properly and then, boom, it starts crashing all of the sudden. I saw one of your other posts on the adobe forum and somebody mentioned double checking that all the proper fonts are still installed so that’ll be my next focus.
Appreciate your help,
db
