Activity Forums Adobe Premiere Pro Titler causing crash?
  • Titler causing crash?
    Posted by Paul on May 15, 2006 at 4:56 am
    Hey folks,
    I’m having a bit(understatment) of difficulty with the titler. I’m working on a movie with Chinese characters along with English for titles and when I click on the two text boxes and then try and drag them or right click and center them, premiere Pro 2.0 stops dead. It locks up my whole system. I eventually had to hard boot the whole thing. I went through this cycle four times until I just decided fine. I’ll work with one text block at a time and no double selected item right clicking. Things are working fine. I have to say that I’ve had trouble with the titler since version 6.5 and on multiple systems. I get the feeling that people in here don’t like to hear negative on adobe but it sure does seem that their software is never “fully” functional and I feel punished for purchasing the Video Bundle premium.
    Anyway, does anyone know of a fix or other? It really makes me gun-shy to relax and create when this stuff “always” happens. It really does seem like anytime I try to relax and just use the program I run into this and that and.
    Before you ask. Yes the system is clean of spyware, viruses. This system is just a stand alone workstation. Windows XP SP2, Dual Xeon with 2 GB RAM ( I know that’s not much), SCSI hard drives, up to date ATI driver for Fire X1 card.
    Paul replied 20 years, 4 months ago 4 Members · 5 Replies
  • Steven L. gotz
    May 15, 2006 at 1:48 pm
    If you create a brand new project and create a new title, can you get it to crash just with two text boxes? Using “normal” fonts like Arial?
    Steven
    https://www.stevengotz.com
  • Paul
    May 15, 2006 at 2:20 pm
    thanks for your quick response. I’ll try the new project with basic fonts. This morning when I awoke I though, “maybe I turned off something in MSconfig” that it needed on startup. I turned everything back on… gamma loader etc. Still had same problem with old project.
    I’ll try your idea tonight.
    cheers,
    Paul
  • Craig Howard
    May 15, 2006 at 8:40 pm
    Try a different playback setting. eg Compatible Mode.
    Click the drop down menu from the Source Monitor to access playback settings.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Tom Scoville
    May 16, 2006 at 1:28 pm
    We have been having problems with the titler also. I installed a new C drive recently, so all software is fairly fresh. But since the new drive went into service, the titler has been acting funny, even on newly created projects. If you move a background item, like a simple colored rectangle, sometimes fonts above it will change size or tracking. Maddening!! Seems like the more complex the title, the more problems we have. I was ready to blame it on our Matrox cards, but I’m not sure if that’s the case now.
    Hope we both find a cure!
    Tom
  • Paul
    May 17, 2006 at 5:49 pm
    Here’s what I’m doing for the meantime. I think that my using Arial and then SimSung (for my chinese text) is causing the titler to die. so I’m not going to do anything where I have to move both simultaneously. so I will click on the arial.. edit it.. move it.. etc. Then click on the SimSung and do the same. Shift clicking and then … there is no then. The application goes into a tailspin.
    p.s. Anyone know or remember the website to make suggestions to adobe?
    Cheers,
    Paul
