Titler
Posted by David Rodey on February 11, 2010 at 10:21 pmI’ve started using ProTitler in with my Sony Vegas Pro 9. I’m not impressed so far. It keeps crashing my system. Do you use something else instead?
John Rofrano replied 16 years, 7 months ago 4 Members · 5 Replies -
John Rofrano
February 11, 2010 at 10:32 pmI still use the original titler but on the occasions where I’ve used ProType it hasn’t crashed my system at all. Do you have any 3rd party fonts installed? Perhaps one of them got corrupt? I’ve also also used Boris Graffiti / Boris RED which plugs into Vegas. It’s a very powerful titler (Graffiti is just the titler in RED).
You might want to look into what’s wrong with your system. The ProType Titler should not be crashing your system.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Mike Hinkel
February 12, 2010 at 4:49 amI have found that it crashes now and then, but I suspect it is because I force it to work too fast. Most times it is when using the effects tabs. Happens
David Rodey
February 12, 2010 at 5:06 pmYeah, I was messing around with it, and that is when it happens. With ProType, can you move the text around in 3D?
John Rofrano
February 12, 2010 at 5:58 pmWith ProType, can you move the text around in 3D?
No, ProType is a 2D titler only. The Boris Graffiti/RED plug-in that I mentioned in an earlier post does 3D.
~jr
