Activity › Forums › Avid Media Composer › TItleMotion AVX
TItleMotion AVX
Posted by Les Kaye on April 7, 2005 at 1:38 pmIs anyone using it here? Any comments, pro or con would be appreciated.
ThanksValerie Shoaps replied 21 years, 5 months ago 3 Members · 3 Replies -
Oakmozart
April 7, 2005 at 7:52 pmAre you on Xpress Pro HD 5, Adrenaline or above? If you are, why not just use Marquee? It’s included, so it’s “free.” Some people have issues with it, but I use it daily for 90% of all my titling. It’s a great tool that goes way above and beyond Pinnacle’s TitleDeko, or other 3rd-party titlers, with the exception of Titlemotion Pro, or Boris Graffiti. Numerous people complain about long render times, but that’s due to problems with their systems and not so much Marquee. I’ve never had the kind of problems with Marquee that other users have complained about.
TitleMotion Pro, is a pretty impressive titler. I’ve only used it once before on another project and it seems like a decent product. I don’t recall if it had glows and blurs in it, but other than that it seemed to work fine. The titles looked decent, but I remember it being a little bit unstable (error and closing, causing me to lose my title…I’ve never had this problem with Marquee). The only problem with TitleMotion is that if you just buy TitleMotion itself, it doesn’t do 3D titles. In order for you to get that, you must buy the TitleMotion Pro add-on, which ends up costing you around $800. Do you want to spend that kind of money on a titler when you have Marquee included, or can get it for $50?
Graffiti’s pretty sweet too, once you learn the interface. But I’m sure you’ve already been playing with it, since it’s been bundled with XDV/XPro for ages.
Les Kaye
April 8, 2005 at 6:24 amThanks for your response. Respectfully, having worked with Marquee on both XPro 5.0 and Adrenaline HD systems, I simply find TitleMotion to be a much faster, and more elegant and powerful solution for my needs.
Valerie Shoaps
April 8, 2005 at 10:31 amIt definitely fills a need. I’ve also used a few other Inscriber products and liked them all.
Valerie
