title track corrupt? too many lower thirds? not the best way to sub title ?
Hi to all,
What is the best way to sub title in Sony Vegas?
I have hours of sub titling coming up and have to get out being stuck with one crash after the other.
I want to do the sub titles in Vegas because I need to print to tape.I have been using (Legacy Plug-in) Video Factory Text on a video track above the image track, but find that after having too many titles, SV crashes.
I have tried to prerender but it also crashes unless I do small pieces at a time, and to even open the file with the complete set of titles is problematic, mostly it crashes when I try to move to the spot from where I want to continue.Before continuing with this method, I would like to know what folks use for heavy sub titling?
Thank you in advance,
Rina Sherman
Filmmaker
https://www.rinasherman.comMy previous question posted in SoCalVegasUsers Group:
— In SoCalVegasUsers@yahoogroups.com, “Rina SHERMAN” wrote:
> Hi to all,
> I have been sub titling an hour long clip (SD) with lower thirds. About half way through, SV started crashing regularly, showing a red screen in the viewer and then mostly closing down or freezing and having to be closed down manually.
> I have tried the following:
> Save file to a different name: same problem
> Created a new project, copied and pasted select all, SV crashed.
> Created a new project, copied and pasted only video and audio track: all fine
> Tried to select all titles to new project: SV crashed.
> Tried to select titles bit by bit and copy and past to new project, it works for first two and then crash.
> Now trying to prerender bit by bit, it worked for the first two and now SV goes “on hold” on prerender at 1 or 2%, then crashes.
> Any ideas of how to get the remaining titles out of what seems to be a corrupted file? To avoid having to do all those title all over again?
> I have hours of sub titling coming up. How can I prevent / avoid this from happening.
> I’m on SV 7 and Windows XP; both working absolutely fine in every other aspect.
> Any help would be appreciated.
> Rina
>Rina Sherman
