Activity Forums Apple Final Cut Pro Legacy Title Scroll: Photoshop settings for FCP
  • Title Scroll: Photoshop settings for FCP
    Posted by Les Kaye on May 17, 2009 at 9:10 pm
    Apologies if this has been covered, but a search didn’t help:
    I’ve received the a psd of the end credits for a 720p film (shot in DVCPRO 720p 23.98).
    File Settings:
    Pixel Dimensions
    2667 Width
    16270 Height
    Document Height
    1280.2 points Width
    7809.6 points Height
    Resolution
    150 pixels
    Canvas Size:
    2667 Width
    16270 Height
    The file is 124 MB. Yes, I know it’s huge. I’ve merged all layers and attempted to scale and animate in Motion, but the image quality was unacceptable after Motion downconverted (dimensions too large). Final Cut seems to scale to the correct resolution, but the colored titles (orange – which I recommended they not use), are starting to break up. I’ve tried flattening the file and the resolution looks terrible in FCP.
    Can someone please recommend the correct settings to be used?
    Many thanks,
    -Les Kaye
    http://www.leskaye.net
    Bob Flood replied 17 years, 4 months ago 4 Members · 4 Replies
  • Walter Biscardi
    May 17, 2009 at 9:01 pm
    Take it into photoshop,
    Flatten the image
    Change the Image Size to 1280 wide to match your 720p timeline. Be sure to “Maintain Image Proportions or whatever that checkbox says so you don’t change the aspect of the timeline.
    This will create a text file the same width as your timeline.
    Now bring that into FCP and try the crawl.
    If it’s still too wide, make the width small enough in Photoshop to accomodate the correct width. I find scaling down files in Photoshop to work better than scaling them in FCP.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Arnie Schlissel
    May 17, 2009 at 9:51 pm
    You’ll need to use AE or Combustion to do this. You won’t be able to do this in FCP or Motion because both of those apps are limited to no more than 4096 pixels in either direction.
    And while you’re at it, make sure you make the orange broadcast safe!
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Les Kaye
    May 18, 2009 at 6:39 am
    Thanks Walter & Arnie. Since this project MIGHT end up with theatrical distribution, would I be better off using AE in terms of ending up with the best results in terms of picture quality?
    -L
  • Bob Flood
    May 18, 2009 at 2:37 pm
    LES
    WOT IS UP!
    Can’t you just copy the titles over to tilemotion and ….whoops! forgot we are past that (ha ha ha)
    AE will always give you the best results, because you have more control over the various aspects you need. I find FCP to be limitied in a lot of the graphic/text manipulation areas, so i am getting better and better at AE (next week i am gonna try Masks! 🙂 )
    and AE really is resolution independent. AND i would follow walters advice about making the crawl as wide as your comp.
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
