Activity Forums Apple Final Cut Pro Legacy Title Safe isn’t visible/not working
  • Title Safe isn’t visible/not working
    Posted by Kai Whittaker on September 12, 2006 at 3:06 pm
    Hi..
    I upgraded my final cut pro studio to version 5.1 and ever since I haven;t been able to see the title safe/action safe lines in the Canvas window. I have the ‘show title safe’ option checked, as well as the ‘show overlays’ option.. when i select the ‘show excess luma’ option it shows me the zebra stripes as it should, and the timecode overlays work fine as well.. it’s just the title/action safe that aren’t wokring properly.
    Any ideas.
    Kai
    Duane Martin replied 20 years ago 3 Members · 4 Replies
  • Jerry Hofmann
    September 12, 2006 at 3:12 pm
    Try trashing your preferences for FCP…
    Jerry
  • Duane Martin
    September 13, 2006 at 6:57 am
    I saw this recently with a client. Check your System Preferences > Displays and ensure that your Colors pop-up button is set to millions. Let us know if that is the issue.
    Duane Martin
    Calgary FCPUG
  • Kai Whittaker
    September 14, 2006 at 2:39 pm
    I tried that but it didn’t work. it was set to thousands instead of millions but changing it to millions had no effect on the overlays. I’m going to try tossing my prefs next.
  • Duane Martin
    September 14, 2006 at 8:28 pm
    I have a better idea. Change the System Preference setting while FCP is not open. Quit FCP, make sure the settings are changed, and then open FCP again and your problem will be solved, I promise. Deleting Prefs is far too often recommended for problems that are simply not understood, and it will not help you with this particular problem.
    Duane Martin
    Calgary FCPUG
