Activity Forums Adobe After Effects Title safe areas in AE v10.0
  • Title safe areas in AE v10.0
    Posted by Ceri Allen on December 9, 2013 at 1:32 pm
    Hi
    I am generally always confused over which ‘line’ I need to work to for title safe areas when creating broadcast graphics (working and delivering at 1920×1080)
    In after effects the default is action safe at 10% and title safe at 20%. Are these the correct values? Also there is then the centre cut safe zones for non-widescreen displays. Which should I work to as a industry standard for broadcast delivery? (obviously if there is a channel tech spec that specifies the I’d follow that, but just wondering whether the default is to allow for 4:3 safe or not?)
    Ceri Allen replied 12 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
