Activity Forums Adobe Premiere Pro title resolution-sharpness
  • title resolution-sharpness
    Posted by Peter Robins on September 23, 2007 at 10:49 am
    I am using PP1.5, and have found that titles are habitually soft when rendered and transcoded. I use Encore 1.5 to master to DVD.
    Are there any tips for increasing the sharpness and clarity or resolution of the titles please?
    Peter Robins replied 18 years, 12 months ago 5 Members · 8 Replies
  • 8 Replies
  • Steven L. gotz
    September 23, 2007 at 5:39 pm
    If you use soft drop shadows on your titles, and avoid whites higher than 235,135,235 and blacks lower than 16,16,16 – you hould get reasonably sharp titles.
  • Vince Becquiot
    September 23, 2007 at 6:01 pm
    And make sure you don’t export to DV going to Encore. You’ll need uncompressed or mpeg2.
    Vince
  • Peter Robins
    September 23, 2007 at 7:36 pm
    Thanks very much! Much appreciated indeed!
  • Steven L. gotz
    September 23, 2007 at 11:10 pm
    I made a typo. The whites are 235,235,235
  • Accountclosed
    September 25, 2007 at 12:25 am
    There is a resolution issue with v1.5 and Still titles.
    If you create a still title, it will render at somewhat reduced resolution, looking jagged and fuzzy.
    My workaround was to switch the title type to Roll and keep it shorter than a page so it remains still. Premiere Pro 1.5 will render it out at dramatically better resolution and clarity.
    Take care,
    Mark & Mary Ann Weiss
    https://www.basspig.com The Bass Pig’s Lair – 15,000 Watts of Driving Stereo!
    https://www.mwcomms.com
    https://www.adventuresinanimemusic.com
  • Peter Robins
    September 25, 2007 at 8:25 pm
    Thanks very much, I had thought it might be a software problem, as I can’t seem to find any options or preferences that would control the set up of titles either.
    Cheers,
  • Cam Walter
    September 30, 2007 at 6:00 pm
    another way to get around this is to export a frame from each title as a bitmap file and import it back into the project…placing it above the same title in the timeline to make sure it matches with the original. this can be extremely time consuming if you have a lot of titles but they come out looking nice and clean upon export.
  • Peter Robins
    September 30, 2007 at 8:01 pm
    Good tip, thanks. I have been looking at the situation much more closely though, and it certainly seems to be a problem with v1.5 in the native resolution it creates titles in, which can’t be changed obviously.
