Activity › Forums › Adobe After Effects Expressions › Title Postion Expression Offset
  • Kevin Camp
    June 23, 2021 at 9:02 pm
    I usually parent the layer that needs to move to the other layer to make the expression a little easier, so in this case parent the 11:30et to the 8:30pt, then add this expression to the ET layer:
    rect = parent.sourceRectAtTime() ;
    x = rect.width ;
    value - [ x, 0 ]
    Then adjust the x position value of the ET layer for the proper spacing.
    After that the x-position of the ET should follow the width of the PT layer.
