Activity › Forums › Apple Final Cut Pro Legacy › Title Looks Unrendered with Cross Dissolve
  • Title Looks Unrendered with Cross Dissolve
    Posted by Doreen Blunt on January 18, 2006 at 3:17 pm
    I’ve checked the archives but I have not seen this addressed. When I add a cross dissolve or a fade to/from color to a title and render it the title looks fine except when it hits the effect. Then it looks unrendered with a very unprofessional looking transistion. Can anyone guide me to a solution?
    Doreen Blunt
    HIPTV LLC
    System: Dual 2.5 GHz PowerPC G5
    Mac OSX Version 10.4.3
    Final Cut Pro 5.0.4
    Shredder replied 20 years, 8 months ago 2 Members · 1 Reply
  • Shredder
    January 20, 2006 at 7:54 pm
    Try doing a full render for that effect/clip.
    Full renders will show up as BLUE on your render timeline (the colored bars at the top of your timeline – render colors are BLUE = FULL Render, GREEN = PREVIEW render, YELLOW = PROXY render, RED – NEEDS RENDER, and so on).
    Simply select the clip/effect area that you wish to render, then mouse click on “SEQUENCE/RENDER ONLY/FULL” at the top of your screen.
    **NOTE – This is a toggle function (meaning it’s either toggled ON or toggled OFF). Thus, your “RENDER ONLY” command will always do a FULL RENDER until you toggle that function off, again. Not all effects need a full render to be previewed in your playback.
