Activity Forums Adobe Premiere Pro Title HELP!! Against Deadline
  • Title HELP!! Against Deadline
    Posted by Mose on September 16, 2005 at 7:06 am
    I’m trying to use adobe premiere to scroll a 6 column 1438 line word document. The document are race results from a local marathona and the columns have info such as time, name, place, and so on. I’m havning trouble keeping the alignmnet and the tab spacing is really wide once I copy and past from word/excel to premiere.
    What I though might work would be if I could make one long PDF file without pages breaks and then animate that, but I can’t figure out how to do that, instead I get 45 seperate pages. Any ideas? Thanks!
    Mose replied 21 years ago 2 Members · 4 Replies
  • Tim Kolb
    September 16, 2005 at 1:52 pm
    How exactly are you having trouble with alignment? Are the tabs not being read?
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Mose
    September 16, 2005 at 8:47 pm
    The trouble comes when the “tab stops” created in word don’t translate into premiere. Premiere just sees the tab without stops, so I get these big gaps between the columns when I copy and paste. Only solution I’ve found is to use Courier font on a flat-text document and stretch the aspect ratio and width. But Courier is pretty skiny for video, even at 12pt I’m barley just fitting title safe.
  • Tim Kolb
    September 16, 2005 at 10:00 pm
    Typically I’ve found it most effective to go back and make three word docs, one each with a column on it. Then you paste as three text objects and line them up.
    That’s about the best solution I can think of for a short turnaround…
    TimK,
    Creative Cow Host,
  • Mose
    September 16, 2005 at 11:58 pm
    Good suggestion. A few more steps but I can see that working as a 2nd option. Thanks.
