Activity › Forums › Apple Motion › Title “Fade In/Out” Timing
  • Title “Fade In/Out” Timing
    Posted by Chad Greene on November 28, 2016 at 10:47 pm
    I created a new FCP Title in Motion and added a fade in/out behavior set to 24 frames for both in/out. When I use the title in FCPX it fades correctly when first dropped in, but when I lengthen or shorten the clip, the fade lengthens and shortens as well. Is there a way to make the fade behavior keep it’s timing regardless of the title’s length?
    Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2×2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
    Chad Greene replied 9 years, 10 months ago 2 Members · 2 Replies
  • Robin S. kurz
    November 29, 2016 at 10:31 am
    You need to use a timeline markers after and before each fade and set them to “Build In” and “Build Out” respectively. Whether “- optional” or “- mandatory” is up to you.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Chad Greene
    November 29, 2016 at 5:23 pm
    Thank you. That was just the clue I needed. I found the details in the Motion help files.
    https://help.apple.com/motion/mac/5.3/index.html?localePath=en.lproj#/motn141baf86
    My title is working perfectly now.
