Activity Forums Adobe After Effects Title effect from AFX to Edius
  • Title effect from AFX to Edius
    Posted by Gego on February 9, 2006 at 2:25 pm
    Is it possible to maintain opacity information when exporting a file from AFX to Canopus Edius Pro3?
    I need to use a programme title/effect over some introshots and I would like to be able to lengthen the effect to the length I need.
    Thx
    Gego
    Gego replied 20 years, 7 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    February 9, 2006 at 4:13 pm
    I would assume that the Canopus CODEC for Edius Pro3 has Alpha Channel support. Just ensure that you select RGB+Alpha in the Output Module with Straight Alpha Channel.
    Your other option is to render a 32-bit TGA sequence.
    HTH
    RoRK
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Gego
    February 9, 2006 at 10:33 pm
    Thanks Rork I’ll have a go.
    G.
