Activity Forums Apple Final Cut Pro Legacy title dissolve problem
  • title dissolve problem
    Posted by Lonnie Goodwin on December 4, 2010 at 10:56 pm
    Hello–
    I’m having a problem when fading a title in and out over an image. It appears that the colors in the image change from before the title to the section with the title. Is there a way to make sure there is no color change under a title?
    Help would be greatly appreciated.
    Lonnie
    Mark Maness replied 15 years, 9 months ago 3 Members · 3 Replies
  • Miriam Lefkowitz
    December 4, 2010 at 11:22 pm
    Did you render the timeline? The image under the title should not change at all.
  • Lonnie Goodwin
    December 4, 2010 at 11:38 pm
    Hi Miriam–
    Yes, timeline is rendered. Not sure if you saw my followup post, noting that the problem is not visible in FCP but in my mpeg4 export. Saw thread saying a possible solution might be to export using native codec, but that’s not possible in this case.
    thanks,
    Lonnie
  • Mark Maness
    December 5, 2010 at 1:25 am
    What has suggested, Lonnie, is to export to the native codec THEN use compressor to export to mp4. Works perfectly every time. Exporting to anything other than the native project codec can result in issues like yours.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
