Activity › Forums › Adobe Premiere Pro › Title crawl’s
Title crawl’s
Posted by Russ Hamm on May 14, 2008 at 7:43 pmHi,
So i want to make a movie where i have a clip showing and below it i have text scrolling,like a karoke video.However,when i try to add text,if the text goes off of the screen it doesnt show in the video.How can i solve this?
ThanksRuss Hamm replied 18 years, 4 months ago 3 Members · 5 Replies -
Jon Barrie
May 15, 2008 at 2:58 amIs this title actaully set to roll/crawl?
If so you should see it on screen and have the options set to offscreen for you. that will push all the text off the screen when it is in the timeline as a clip for you.
– Jon 🙂How many editors does it take to change a light bulb?
http://www.jonbarrie.net -
Russ Hamm
May 15, 2008 at 4:19 pmYes,i have it set to crawl.
What i mean is that i have a few sentences of text i need to scroll across the bottom of the screen.However,when i type it all into a title,only the first 3-4 words scroll,the rest stays off screen. -
Phocas Kroon
May 15, 2008 at 9:11 pmYou have to type after the last word so much blanks that the text can move till the end.
Good luck
Phocas Kroon
Jon Barrie
May 16, 2008 at 3:43 amThe problem you describe has never happened to me. I would be certain you have the crawl setting, type something that is just alskdnf;lkasdnfhasdfj garble until it runs off the screen, set the roll/crawl options to offscreen and see how that works.
Otherwise there is something wrong with your install. Reinstall the software.
– Jon 😉How many editors does it take to change a light bulb?
