Activity Forums Adobe After Effects Title Crawl In AE. Reducing The Flicker Effect.
  • Title Crawl In AE. Reducing The Flicker Effect.
    Posted by Paul Whishaw on May 3, 2005 at 6:12 am
    I’m making a credit list for Final Cut and I’m having trouble not getting flicker on the sequence. The sequence is white text on a black background. I’ve tried a few different fonts and the font size is around 30 or so.
    Is there any font that lends intself to reducing the flicker on crawling text? I’ve put a slight fast blur on the text and tried a soft shadow but the flicker is still bothersome.
    Thanks in advance.
    Paul Whishaw replied 21 years, 4 months ago 4 Members · 4 Replies
  • Stu Pond
    May 3, 2005 at 10:14 am
    You’ll need to render the footage as interlaced to remove the flicker. White on black seems worst than anything though.
  • Ruediger Chmielus
    May 3, 2005 at 12:45 pm
    Right!
    1.) Render the Animation in fields (interlaced).
    2.) Don
  • Martti Ekstrand
    May 3, 2005 at 1:35 pm
    Or try a adjustment layer on top using Effect>Video>Reduce Interlace Flicker – mostly a value of 1 works perfect. With this you can still render in frames. Also you can try enabling motion blur.
    cheers
  • Paul Whishaw
    May 3, 2005 at 3:56 pm
    Fantastic suggestions guys. Thanks very much.
