Activity Forums VEGAS Pro Title Assistance in Vegas 2026
  • Title Assistance in Vegas 2026
    Posted by Andy Winn on July 21, 2026 at 1:07 pm
    Recently upgraded to Boris Vegas Pro 2026 but having difficulty with titles. Attempting to create a rectangle box in lower left corner to introduce rehearsal video title. Watched the Boris BCC title for Vegas 2026 but the titler does not appear in my FX. Can anyone direct me to how to open the new BCC titler?
    Andy Winn replied 1 month, 4 weeks ago 2 Members · 5 Replies
  • Silviu Negoita
    July 21, 2026 at 1:42 pm
    Hello!
    I am not very experienced with the Boris Vegas, but I did some research on the topic.
    If you’re using VEGAS Pro 2026, the new Boris FX Titler isn’t included as a standard built-in Video FX. BCC Title Studio is part of the Boris Continuum (BCC) package, so it will only appear if Continuum is installed and licensed. Therefore please check the following things:
    1.Make sure Boris Continuum is installed, not just Vegas Pro.
    2.Open the Video FX window and look under BCC 3D Objects or search for “Title Studio”
    3.If it’s still missing, try Options → Preferences → VST/OFX (or the plugin manager) and rescan your plugins, then restart VEGAS.
    If the problem still persists, please let me know which edition of Vegas pro you are using(Edit, Plus, Ultimate) and if the plugin is PROPERLY installed on your device.
  • Andy Winn
    July 21, 2026 at 2:54 pm
    Wow. Thank you so much. I have used Vegas for years (though this is not my main job so I am still a novice when it comes to all features). I realized the BCC is not installed into my Vegas Pro 2026 though it is installed on my computer. I will try to figure a way to incorporate it into my Vegas Pro 2026. Thank you so much for even letting me know the need to install it. I guess I thought when I downloaded the updated 2026, it would come installed with the Vegas Pro 2026 package.
  • Andy Winn
    July 21, 2026 at 3:04 pm
    Okay…it is still missng. Uggghhhhhh. I intended to purchase the “ultimate” package. Again, Continuim is installed on my computer…just not in Vegas. Let me do some additional checking around in my license that we just upgraded…
  • Silviu Negoita
    July 21, 2026 at 3:23 pm
    I see, If you are sure Continuum is installed but doesn’t appear anywhere in VEGAS, check the following:
    Open the Boris FX Hub( I think that’s what it’s called) and make sure Continuum is activated with the same license you’re expecting(Especially if you upgraded to Ultimate)
    In Vegas, go to Options – Preferences – VST Effects then restart VEGAS to force it to rescan plugins
    Check if any BCC effects appear in the Video FX panel. if none appear, it usually means VEGAS is not loading the Continuum OFX plugins at all.
    One last thing, if you just upgraded to Ultimate edition, it may also be worth running the Borris installer again to ensure the OFX plugins are installed for the current version.
    One question, Are there any BCC effects in the Video FX panel, or is the entire BCC category missing?
  • Andy Winn
    July 21, 2026 at 4:24 pm
    Just to circle back. I was able to install it. Thank you so much for your support.
