Activity Forums Apple Final Cut Pro Legacy Title 3D locking up
  • Title 3D locking up
    Posted by Paul Nevison on November 3, 2006 at 6:04 pm
    hey there
    Title 3D is locking up once I launch it from the generators menu or open a text clip to edit. I have tried trashing the prefs for both title 3D and FCP.
    anyone else seeing this?
    G5 DP 2.0 (Power PC)
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    BMD Decklink Extreme 5.7.2
    PAL Land
    Sean Lander replied 19 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Lu Nelson
    November 3, 2006 at 7:05 pm
    Hmmm… I have almost the exact same system as you and haven’t seen this for some time; but when I did have it I was able to fix it by trashing the title 3d prefs. Are you sure you’re getting them all? You might want to do a search for “boris”.
  • Paul Nevison
    November 3, 2006 at 7:07 pm
    thanks Lu
    I have had it intermitently in the past and i recall fixing it by trashing boris prefs….i just rebuilt my machine this week and its the first time ive tried working on a project since and now title 3D wont work…ill do another serach to make sure ive trashed all the boris prefs
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Paul Nevison
    November 3, 2006 at 7:13 pm
    trashed all the boris title prefs and it’s still locking up 🙁
    any ideas?
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Bob Vick
    November 3, 2006 at 9:40 pm
    Having similiar issues with 3D. I open the type window and click reset pallette and it locks up. I have used rescue and repairs. It is working now but I Have “fixed” it several times. I also have a G5 2.0, AJA Kona LS, Atto 4d
    b
    Bob Vick sr promo guy @ ch3 & CW wwmt tv, kalamazoo, mi
  • Paul Nevison
    November 3, 2006 at 10:37 pm
    several restarts and multiple trashing of boris and FCP prefs seems to have “fixed” this issue – until next time!
    4.0G RAM
    OS 10.4.8
    QT 7.1.3
    FCP 5.1.2
    PAL Land
  • Tom Meegan
    November 4, 2006 at 4:47 pm
    I’ve had this problem recently also.
    I found it is more likely to occur if I have Motion open, and most likely to occur if LiveType is open.
    I’ve been saving my work more as a result, which is a good thing :->
    Tom
  • Sean Lander
    November 4, 2006 at 11:36 pm
    No quite the same thing but I find that if I try to open a boris title that has been rendered I get a FCP crash.
    Whole app disappears. Solution is to unrender the title first. Bizarre.
