Activity › Forums › Apple Final Cut Pro Legacy › Tips needed – Footage with heavy grain / rgb-noise
  • Tips needed – Footage with heavy grain / rgb-noise
    Posted by Birgit Bachler on October 10, 2011 at 1:20 pm
    I am editing some footage that unfortunately suffers from very bad image quality. I am not sure what filters are best/quickest to enhance the material. Especially because it’s quite a huge amount of video (several hours in PAL) I am not sure which FCP filter or maybe Plugin, other software is worth using without having to render over it for hours (these were the solutions I have come across, also re-rendering in AfterEffects, but that seems like not worth the hassle…).
    I posted some sample images below and would be very grateful if someone has an idea what could be the most effective fix.
    Thanks in advance!
    https://postimage.org/image/1e90xwq78/
    https://postimage.org/image/1e9wd4bl0/
    Birgit Bachler replied 14 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
