Activity Forums VEGAS Pro Tips for working with large projects
  • Tips for working with large projects
    Posted by Bradley Mowell on March 6, 2008 at 8:26 am
    I was wondering if you guys could provide some tips for working with large projects (1 hr or more) in terms of keeping things from moving around when you don’t want them to.
    I’ve started trying to group and lock events that I’m finished with as well as locking my envelopes to events.
    But what are some other methods that I could use to improve my workflow that would ensure that things stay where I want them?
    I just spent a week reconstucting several sequences that I unwittingly shuffled around.
    I’ve order vegas 8.0 (using 7.0 now) so that I can download the popular autosave script to be able to have multiple saves in the event that I screw something up.
    Any other suggestions?
    Brad
    Edward Troxel replied 18 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Edward Troxel
    March 6, 2008 at 2:00 pm
    First of all, I turn OFF “auto ripple”. I don’t want things moving without me knowing about it. Secondly, I usually break the project up into pieces and then combine all the pieces into a “Final” project.
    Edward Troxel
    JETDV Scripts
  • Bradley Mowell
    March 7, 2008 at 1:10 am
    Ed,
    Thanks for the response.
    How large are the pieces that you are talking about from a time standpoint?
    I wish that I would have had your autosave script the week before last when my problems occured. Sony just sold another copy of vegas 8 because of you.
    Brad
  • Edward Troxel
    March 7, 2008 at 3:23 am
    For the projects I do, a “single piece” could be anywhere from 2 minutes or 1 hour or so.
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    March 7, 2008 at 2:58 pm
    Brad, long before Vegas 8 and Edward’s script came along, I got into the (highly recommended) habit of saving a project as a new version number after every few changes.
    For example, a 10 minute video I did last summer was up to version 75 by the time I was done 🙂
    I’ll also echo Edward’s recommendation about leaving Auto Ripple off as it gets more people into more problems than almost any other option.
  • Bradley Mowell
    March 7, 2008 at 11:06 pm
    That’s a good idea, Mike. I’d thought of doing that myself.
    Currenly, I’m using acronis backup software, which I do not like, and have been incrementally backing up my vegas project folder every hour…but it only works about a third of the time. Saving under different file names would be much easier and probably work more consistenly. Acronis is garbage, unless all you want to do is just do a single backup of your PC IMO.
    Auto-ripple has gotten me into trouble several times.
    I’ve kind of gotten into the habit now of grouping and locking areas of my project that I am not working on. I can’t tell you the number of times that things would move off-screen that I would not notice until after I saved the project a couple of times.
    Brad
  • Kert
    March 8, 2008 at 1:37 am
    I recently completed a movie project (about 90 min). http://www.solovereturns.com
    What I did was I made a separate Vegas project for each scene (4-5 minutes each). Then imported each scene into a Master Project. There were about 20-25 scenes.
    In the Master Project the nested (scene) projects handle as a clip, you can shoten them etc. But most importantly each sub (nested) project can be reopened and edited separetly and when closed all the changes show up in the Master Project.
    Worked out well.
    JK
  • Bradley Mowell
    March 8, 2008 at 9:29 am
    John,
    That’s really great advice.
    I appreciate you input and will try to take a peek at your movie.
    Brad
  • Edward Troxel
    March 8, 2008 at 2:14 pm
    If you’re in Vegas Pro 8, you can download my “Auto Save” custom command and it will automatically give you a series of date/time stamped backups. You can specify how often you want it to back up and it will give you up to two backup copies each time.
    Edward Troxel
    JETDV Scripts
