Tips for syncing audio in large project with PluralEyes
Hi
have used Plural Eyes in smaller projects in the past with no problem
But currently using it in a larger project with several dozen clips that need syncing
Following these steps
https://www.singularsoftware.com/help/pluraleyes_pp/howto_pluraleyes_premiere.htmlSometimes it works, other times I need to resort to matching the waveforms then removing the echo…quite the pain.
I must be doing something wrong. Can anyone help?
Local is the new global
