Activity Forums Boris FX Particle Illusion tips and tricks about create new emmiter library
  • tips and tricks about create new emmiter library
    Posted by Arash on May 23, 2005 at 4:25 am
    some tips and tricks about create new emmiter library in PI 3.01a
    hi
    i need some tips about create new emmiter library in PI 3.01a
    because when i create a new emmiter to add to my libraries
    its size is very big
    and when i decrease size of images hat i use in that emietr
    its quaity is falling down
    and i don’t satisfy it
    some tutorials and guidence about this topc is very helpful./
    Aharon Rabinowitz replied 21 years, 4 months ago 3 Members · 3 Replies
  • Alan Lorence
    May 23, 2005 at 7:44 pm
    You should always use the smallest size images that you can and not lose quality. When particleIllusion has to scale particle images very small or very large, the image quality degrades.
    If you’re using a “full color” image as the particle shape, do you really need it? Full-color shapes use much more memory than greyscale shapes. One tip: if you have a full-color shape and then check the “intense” option for that particle type, there is an internal conversion to greyscale. So if you’re not using that particle shape anywhere else, you might as well import it as greyscale.
    Also, if you are using an image sequence, then there may not be anything you can do about the size: a lot of frames takes up a lot of memory.
    Don’t know if this helped at all. If you can post some examples of the emitter and problems you’re having with quality, and give more info about particle shape size, etc., that would help me give a better answer.
    Alan.
    wondertouch
  • Arash
    May 29, 2005 at 4:41 am
    for example when i have some human that come toward (with with black background option
    in poser;poser have not any option like alpha channel)
    i have set a emmiter like explosion behind them
    corner shape of those human isnot very smooth
    and overall final output donot satisfy me
    i see that corner shapes black (color of background)
  • Aharon Rabinowitz
    May 29, 2005 at 7:00 am
    It’s been a while since I used poser, but it absolutely has the option for Alpha Channel. Make sure your render settings have alpha channel enabled, and that you’re image format is capable of keeping it – TIFF, TGA, PNG – but not BMP or JPEG.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
