Activity Forums Adobe Premiere Pro Tip: getting Premiere titles into After Effects
  • Tip: getting Premiere titles into After Effects
    Posted by Randy Mcwilson on February 23, 2008 at 11:37 pm
    One of the most annoying aspects of rendering out Premiere Pro sequences in AE is the dreaded “Black box of death” (as opposed to the “Blue screen of death”). One is Adobe’s fault, the latter, Microsofts. This is because After Effects does not import anything made in the premiere title tool. It will render out a black box that is great for simulating a cubist’s interpretation of a black hole, but totally useless for real compositing.
    Here is an EASY workaround (besides just making all of your titles in Photoshop or AE)
    1. Open title tool and make the title normally. Close title tool
    2. Right click on the title in your project window and select “Open in source monitor” (this will put the title into a clip window with black (clear alpha) as the background
    3. Now select File–> Export Frame
    4. Under settings, change from Bitmap to Targa
    5. Change (under the video tab) the color depth from millions to “Millions+ of colors”) this saves out a still image of the title with an alpha channel
    6. In your Premiere timeline, use the targa (.tga) file, NOT the premiere title (.prtl)
    Hope this helps!
    Randy
    Matt Kresling replied 10 years, 2 months ago 6 Members · 5 Replies
  • Steven L. gotz
    February 24, 2008 at 12:04 am
    Either that, or create your titles in AE in the first place.
    Steven
    https://www.stevengotz.com
  • Tom David
    October 4, 2014 at 12:40 am
    That was a useless comment Steven – I hope you’re attitudes have changed since this post considering the website you run…
    Tom
    https://www.tomdavid.com.au
    Cheers,
    Tom
    Camera Operator – Editor – Motion Graphics
    (https://www.tomdavid.com.au)
  • Tulio Drumond chaves
    March 5, 2015 at 8:53 pm
    Great Tip!!!
    Thank you!
  • David Richmond
    May 3, 2016 at 9:51 pm
    This was a great tip. I created a whole mess of FPO titles that I now want to move in AE. Big time saver. Thank you.
  • Matt Kresling
    June 29, 2016 at 7:22 pm
    Obviously what Steven is saying is that you should forego making titles in Premiere and wait until bringing the project into After Effects. Exporting each one individually, creating an un-editable title in the process, is sort of ridiculous. Adobe should fix that.
