Activity Forums VEGAS Pro Tiny Gaps in Vegas Timeline
  • Tiny Gaps in Vegas Timeline
    Posted by Matt Whittemore on June 26, 2012 at 6:04 pm
    Hi. When I’m done with an edit in Sony Vegas 11 there are sometimes tiny, sub-frame sized gaps throughout. I know that when I’m inserting clips I’m inserting at the end of the previous one. Often times doing L/J cuts. Every gap seems to be the exact same size of .2 frames. Does anyone know why this happens and how to stop it from happening?
    James Houghtaling replied 14 years, 2 months ago 6 Members · 8 Replies
  • 8 Replies
  • Angelo Mike
    June 26, 2012 at 7:47 pm
    Do you have quantize to frames turned on? If you have it turned off while editing, but then turn it on, events that you haven’t placed on exact frames will be sort of stuck in that small region between frames, though the fix is as simple as dragging clips/changing their length.
  • John Rofrano
    June 26, 2012 at 11:12 pm
    Yea it sounds like you’ve disabled quantize to frames which would cause fractional frame gaps.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Nigel O’neill
    June 27, 2012 at 3:14 am
    I thought leaving quantize to frames enabled is a no-no and can result in audio sync issues, or have I got it wrong?
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Matt Whittemore
    June 27, 2012 at 12:15 pm
    Yes, I do have it enabled. Should I not?
  • John Rofrano
    June 27, 2012 at 12:22 pm
    Quantized to frames should always be on unless you are making an audio only recording. If you place video on the timeline without having quantized to frames on, you are going to have problems.
    ~jr
  • Matt Whittemore
    June 27, 2012 at 12:27 pm
    Maybe it was off and got turned on halfway through somehow. Thanks for the info!
  • Roger Bansemer
    June 27, 2012 at 2:54 pm
    I’ve recently discovered something about those gaps and the frame not hitting the framed mark but falling in the middle.
    You can move the audio independently from the video anywhere between the frame and it will stick and not snap to the frame marker. This is good especially when you are trying to remove a click or something. However, when you then move the video it will snap to where the audio event is which sometimes happens to be in the middle of one frame.
    Roger Bansemer
  • James Houghtaling
    June 27, 2012 at 10:49 pm
    I always turn quant2frame off when aligning my video tracks in order to sync the audio to the master track. Then I turn it back on. I have not seen any little gaps though.
    My Hardware:
    Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM Win7 64bit.
    My Software:
    Vegas Pro V11 with Boris Continuum Complete 8, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff.
