Activity Forums VEGAS Pro Timing is messed up?
  • Timing is messed up?
    Posted by Tessa Arguello on September 15, 2011 at 11:58 pm
    I don’t know what it’s called, but the little orange line that appears when you put two clips back to back doesn’t show up for me anymore. Is there a setting I have to change to get it back?
    If you can’t understand it, I can try to give more detail about it
    Matt Crowley replied 14 years, 11 months ago 3 Members · 3 Replies
  • Mike Kujbida
    September 16, 2011 at 12:53 am
    It’s called Snapping.
    Options -Enable Snapping.
    F8 is the shortcut.
    It should be a toolbar icon too.
  • Tessa Arguello
    September 17, 2011 at 12:33 am
    Thank you so much, but one mmore questions. I guess I played with the settings trying to get it back too much, because now, every time I cut a clip the one next to it is dragged into its spot. Sorry to bug you, i’m just clueless with the settings.
  • Matt Crowley
    September 17, 2011 at 8:53 pm
    You have accidentally enabled “Ripple Edit”. Press Ctrl+L or click the icon on the toolbar that looks like a left arrow above two video events.
