Activity Forums VEGAS Pro Timewarp Vegas Movie
  • Timewarp Vegas Movie
    Posted by Tom Heine on September 25, 2009 at 4:05 pm
    Hi there, sorry if that has been asked before but
    I’m looking for a smooth way to go from normal speed of a single track to a full stop and then smoothly speeding it up – back to normal speed.
    Is that possible at all?
    If not: is there a reasonable way to do this kind of stuff in Vegas Movie Maker 9 or would I need a Pro Version for this?
    Thanks a lot
    t
    Tom Heine replied 16 years, 12 months ago 3 Members · 3 Replies
  • Terry Esslinger
    September 25, 2009 at 4:15 pm
    In the pro version – the velocity envelope.
  • Jermaine Tonkes
    September 25, 2009 at 8:56 pm
    apart from velocity enveloppes, you can try this:
    put your time line on the beginning of your time warp, then press S (shortcut for split track). Then put your timeline on the end of your warp time and press S again. now you have isolated your time warp track.
    now press CTRL and drag your clip to your desired clip speed (your clip will have these triangle shaped lines now).
    Connect the clip after your timewarp to the new warped clip. You can fade them in a little bit to add some smooth transitions.
    hope it helps!
    Life’s good. yeah, I know. I’m not good in filosofy but er, life’s good.
  • Tom Heine
    September 27, 2009 at 5:08 am
    thanks for the responses :o)
    so other than “go pro” it’s “do stone-age”? :o(
    Like isolating the timeline till the time of full stop, splitting it up
    -10% -20% *** -90% … fullstop … +10% +20% *** +90% … regular speed
    and then CTRL+drag each and every individal package to the appropriate speed?
    woooooooow – that sounds like … “don’t”
    I mean there is no “batch command” or anything?
    because getting it to gradually slow down and speed up this way is like… analog ;o)
    Thanks for participating
    t
