Activity Forums Adobe After Effects timewarp motion blur
  • timewarp motion blur
    Posted by Alex Harding on August 18, 2006 at 9:31 am
    hi
    using the timewarp effect to add motion blur to a pre rendered sequence (without actually doing any retiming). So far so good. However i can’t get the matte layer to work.
    Is it possible to use a matte to define areas of the image that will be effected? Because the matte i have seems to make no diference to the final image.
    thanks in advance,
    Alex
    Peter Litwinowicz replied 20 years, 1 month ago 4 Members · 4 Replies
  • Reloaded
    August 18, 2006 at 12:25 pm
    Hi there.
    There is a video tutorial at Andrew Kramer’s site that shows how to create a matte for a video. It’s a suicide movie, I know you are creating a very different comp from the one at the video, but maybe the part of the Matte (very good) helps you. Here is the link https://www.videocopilot.net/videotutorials/suicide/index.htm
  • Alex Harding
    August 18, 2006 at 2:01 pm
    sorry, i already have the matte made, the problem im having is that the matte doesn’t seem to make any diference to the timewarp effect, regardless of the “matte layer” settings
  • Jack Binks
    August 18, 2006 at 5:27 pm
    Hi there,
    The matte input to timewarp is to do with segmenting the image for motion estimation purposes (essentially use the matte to define the foreground object with different motion so as to help prevent artefacts which may otherwise be introduced). If you’re looking to only affect a particular part of the image use the matte as a trackmatte to laer the moblurred part of the image over the original.
    HTH
    Jack
    The Foundry, UK
  • Peter Litwinowicz
    August 18, 2006 at 5:47 pm
    [Jack@TheFoundry] “If you’re looking to only affect a particular part of the image use the matte as a trackmatte to laer the moblurred part of the image over the original.”
    So what you are saying is that there are two options:
    1) matte the original object and motion blur just the object and place over the original footage. In this case, you’ll see the motion blurred edge over the original non-motion blurred edge of the object after the composite is done.
    OR
    2) track matte after motion blurrring, in which case the motion blur will not affect the edge of the object being blurred.
    FYI, Our ReelSmart Motion Blur Pro ( https://www.revisionfx.com/mblur.htm ) allows you to apply a motion blur to each of 2 layers individually (using a matte, just like TimeWarp). In the case of applying motion blur to the front object only, RSMB will first fill in the hole in the background automatically, blur the front object and internally composite the blurred front object over the filled-hole background. Note that this creates a different kind of artifact (the filling process is not perfect either 🙂 ), but often produces a less objectionable result. Your mileage may vary.
    Pete Litwinowicz
