Activity Forums Adobe After Effects timewarp – lengthen clip?
  • timewarp – lengthen clip?
    Posted by John Tissavary on February 1, 2008 at 10:28 am
    If I use the timewarp node at 50%, my clip length is still the same on the timeline – how do I now increase the total length of the clip so I can playback & render the entire sequence?
    thanks,
    jt
    john tissavary
    TRAkTION*
    *commercials *music videos *di
    hollwyood
    http://www.traktionfilms.com
    Kevin Camp replied 18 years, 7 months ago 2 Members · 1 Reply
  • Kevin Camp
    February 1, 2008 at 3:20 pm
    select the clip and choose layer>time>enable time remapping…. it will add two key frames for time remapping, don’t move those, but now you can drag the out point of the clip for the duration you need. note, you may also need to lengthen you comp’s duration in the comp settings.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
