Activity Forums Adobe After Effects timewarp: extending clip beyond original duration?
  • timewarp: extending clip beyond original duration?
    Posted by Ray on February 9, 2006 at 9:53 pm
    If I apply the timewarp effect to a clip and reduce the speed to 25%, how do I extend the clip beyond its original duration? It gets clipped when using a reduced speed. I can’t seem to extend a clip’s length like I can with time remapping.
    Ray replied 20 years, 7 months ago 2 Members · 2 Replies
  • Mike Clasby
    February 9, 2006 at 10:31 pm
    If you just need to extend the clip length (the comp is longer than the clip), right click the footage in the Project Window, Interpret Footage > Main, then loop the footage enough to cover your extended time (4 loops if whole clip is %25).
    If the comp is too short to handle the lengthrnrd footage, Composition > Comp Settings.
  • Ray
    February 9, 2006 at 10:40 pm
    Sweeeeeeeeeeeeeeeet.
