Activity Forums Avid Media Composer Timewarp Effect
  • Timewarp Effect
    Posted by Genevieve Baker on April 17, 2008 at 10:20 pm
    When I applied Timewarp FX, the length of the clip stayed the same even though the speed changed. Is it possible to change the duration of the clip as it changes speed? Or do I need to do the FX in stages?
    Grinner Hester replied 18 years, 5 months ago 3 Members · 2 Replies
  • Jon Zanone
    April 18, 2008 at 11:27 am
    If you are on XPress, you don’t have much control over motion effects. Media composer has keyframable motion effects. Which system are you on?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Grinner Hester
    April 18, 2008 at 2:18 pm
    you need to change the duration of your clip with trimming.
    your keyframes for speed changes with change accordingly to the trim.
