Activity Forums Apple Final Cut Pro Legacy Timers after log and transfer
  • Timers after log and transfer
    Posted by Noam Osband on September 17, 2010 at 8:18 pm
    So, I recently went tapeless, and I’m getting used to it. When I now look at captured footage in the viewer after uploading it through log and transfer, I cannot figure out what the timers are referring to. It doesn’t seem like they are referring to time within the clip, unless I am somehow reading it wrong. The footage is 24fps. Am I missing something? I asked someone else who said they have the same issue
    Noam Osband replied 15 years, 11 months ago 2 Members · 2 Replies
  • John Fishback
    September 17, 2010 at 8:35 pm
    What kind of footage & what codec was used? Why do you think it’s wrong? Did you shoot with timecode and it’s not showing up?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Noam Osband
    September 18, 2010 at 11:07 pm
    It’s 24 fps in a Pro Res 422 codec. I now see that the time code box is giving me the time for where I was on the SD card I was using. In my workflow, however, I typically watch the clips in QT after transferring them, making notes on them. This means I’m making notes on timing specific to the clip. Is there any way to change FCP so that the time code box just gives me timing for the specific clip?
