Activity Forums Apple Final Cut Pro Legacy timeline won’t render
  • timeline won’t render
    Posted by Nathan Golon on January 9, 2010 at 11:05 pm
    I’m working with HDV 108060i in FCP 6. I render my timeline, and it will render, however when I click on the timeline to begin editing again, it reverts to being unrendered. This started happening over the last few weeks, and now it happens every time I render. I looked over all my settings and everything appears to be the same as it was before I started having this problem. Any thoughts about what the issue could be? Thanks.
    Nathan Golon replied 16 years, 7 months ago 2 Members · 3 Replies
  • Nathan Golon
    January 9, 2010 at 11:48 pm
    a bit more info… sometimes after rendering I can click on the timeline and it stays rendered, but as soon as I navigate away from FCP (to check email in another window, for example) and then go back to my timeline, it becomes un-rendered again.
  • Matt Lyon
    January 12, 2010 at 7:34 pm
    Nathan,
    Did you check that the render scratch drive is set to a valid location, and that there is enough room on the disk? It could also be a problem with the read/write permissions for that location. As a test, you could try setting the render location to a different folder and see if that fixes the problem.
    Hope this helps,
    Matt Lyon
    Editor
    Toronto
  • Nathan Golon
    January 13, 2010 at 12:15 am
    Thanks so much, Matt. I changed the location of my scratch drive and that seems to have done the trick.
