Timeline vs. DVDA
Posted by Dave Edwards on July 10, 2012 at 4:50 pmA DVD produced directly from the timeline seems to me to be sharper than that produced via DVDA using an MPEG2 DVDA template. I need menus so would be very grateful for pointers as to how to optimise picture quality. The Vegas file is 1920×1080, 25FPS PAL.
Dave Edwards replied 14 years, 1 month ago 4 Members · 8 Replies -
Jeff Schroeder
July 10, 2012 at 5:05 pmDave,
If your source mpeg is too large DVDA will have to re-encode it. You have much less control over the renderer in DVDA. That is why it is best to produce a compliant file inside Vegas that will not require compression in DVDA.
I suppose you are already using the Mpeg-2 templates designed for DVDA. What size is your rendered video file(s)?
Jeff
2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
Nigel O’neill
July 11, 2012 at 3:40 amWhen I use the DVD-A template I always adjust the quality slider to 31 under Customise. I think it defaults to 17.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Dave Edwards
July 11, 2012 at 8:17 am -
Jeff Schroeder
July 11, 2012 at 12:30 pmDave,
What is the size of the files you are plugging into DVDA?
How long does the build take when you press Make-DVD?
Jeff
Mike Kujbida
July 11, 2012 at 12:45 pm[Dave Edwards] “I forgot to mention that the duration is 42 minutes.”
In that case, use a custom CBR setting of 8,000,000 for your MPEG-2 encode (i.e. render).
I use this for any program under 70 minutes.
Anything longer and I use a bitrate calculator to determine optimum VBR settings.
My favourite is the one found at https://www.johncline.com/bitcalc110.zip -
Dave Edwards
July 11, 2012 at 2:21 pmMike: thanks very much for that,- I’ve downloaded that useful app, and will try it out.
Dave Edwards
July 11, 2012 at 2:22 pmI’m definitely using the Vegas DVDA template! It looks to me as though this is a bitrate issue,- but thanks for your help!
