Activity › Forums › VEGAS Pro › Timeline troubles
  • Timeline troubles
    Posted by Skunkmonkey on November 13, 2007 at 5:24 pm
    Hello…newbie here Vegas Pro 8.
    My timeline somehow got very large (1hour) as I was working on a 3 min video. I think it got that way when I pulled a large piece of media and then deleted it.
    When I render the video it comes out an hour long even though the events are only 3 mins. I have checked to make sure there is not some small event out past the 3 mins in the timeline.
    Is there a way to delete this extra timeline or is there a way to choose in and out points like you do in the DVD software? I am trying to render an file for the internet and do not need the mpeg2 used for DVDs.
    thanks for the help,
    aaron
    Edward Troxel replied 18 years, 10 months ago 4 Members · 4 Replies
  • Mike Kujbida
    November 13, 2007 at 7:17 pm
    My suspicion is that there’s a tiny sliver of an event down at the 1 hr. mark.
    To confim this, click thr FFWD button and see if it ends where you think it should or way down the timeline.
    If, as I suspect, it’s the latter, delete it and you’ll be OK.
  • Terry Esslinger
    November 13, 2007 at 9:38 pm
    If you continue to have a problem afetr Mikes solution you could try this:
    Make your three mibute video into a region and then render it to a new track. Should not lose any resolution. Then delete the old track. Good luck.
  • Skunkmonkey
    November 13, 2007 at 9:45 pm
    Thanks for the help. I believe it was a marker stuck out there. I did not think it would read that as part of the video.
    I went in and trimmed the whole thing and it seemed to work.
    Thanks again.
  • Edward Troxel
    November 13, 2007 at 10:31 pm
    If it’s a nested VEG file, and depending on the version of Vegas you’re using, that can happen. Was it nested? And what EXACT version of Vegas are you running?
    Edward Troxel
    JETDV Scripts
