Timeline to videotape?
Hello. I’m using Adobe Premiere Pro 2.0 I’m trying to create a videotape from the timeline.
I used to do this quite a bit a few years ago, but vhs use has really dwindled so I don’t see it anymore.
Back then I had a Matrox RT2000 and Adobe Premiere 6.5. I would simply setup the break-out-box for analog out, hit record on the vcr and run the timeline. No problem.
But, I no longer have the Matrox. I have a Canopus ADVC110 and I can’t get it to work. I have the firewire plugged into the back of the 110. I also have the s-video plug and rca audio cables plugged into the back and running into the “in” ports of the VCR. I have tried recording on channels L1, F1, 2, 3 and 4. Nothing.
I suspect that the Matrox had some software configuration with Premiere and the ADVC110 doesn’t. But I don’t know what to do to configure it so video runs from Premiere to the 110.
Can someone explain this to me?
