Activity Forums Apple Final Cut Pro Legacy Timeline stuck on 20 secs
  • Timeline stuck on 20 secs
    Posted by Ronald Lindkvist on August 8, 2008 at 12:34 pm
    Hi friends and colleagues!
    FCP is teasing me again.
    This time I want to export a project through the Quicktime Converter. I did a 20 sec test-print, and it looked just dandy.
    Since the test, I haven’t been able to print anything out in any project – except for the 20 sec…
    I have a specialist looking at the ptob as we speak. but he’s about to throw the towel in the ring as well…
    Where did I go wrong? Trash prefs a solution?
    Thanks and have a nice weekend!
    Regards
    Ron
    Christopher Smith replied 18 years, 1 month ago 3 Members · 4 Replies
  • Jim Calahan
    August 10, 2008 at 2:15 am
    Did you try to remove the in and out points in the timeline.
    Jim Calahan
    KVIE, Sacramento
  • Ronald Lindkvist
    August 10, 2008 at 8:46 am
    Hi Jim,
    Thanks for your input. Yes, i did remove in/out points.
    Can the 20 sec capture be defined somewhere in the prefs?
    Regards
    Ron
  • Jim Calahan
    August 10, 2008 at 5:56 pm
    What are you trying to export? If it’s .wmv you need to upgrade your flip4mac as there is a limit as to the length it will export.
    Jim Calahan
    KVIE, Sacramento
  • Christopher Smith
    August 13, 2008 at 5:09 am
    I had the same problem today, with exports limited to 14.91 seconds, and subsequent exports (I was exporting scenes from a timeline, one after the other) exporting one section earlier than the In and Out markings…spooky!
    Solution: My sequence was set to 24 fps, and I was exporting to Sorenson 3 [yes, from a dual G5] with the frame rate set to “Current.” When I changed the export frame rate to “24 fps,” the exports proceeded normally, and the results extended from In to Out point.
    Actually, the exports extended from In point to 2 frames short of the Out point, so I had to mark my Out point each time 2 frames later than desired to get the intended result.
    Chris Smith
    CBN Animation
