Activity Forums Adobe Encore DVD Timeline repeating advice
  • Timeline repeating advice
    Posted by Alan Howard on September 18, 2007 at 1:46 pm
    Having just spent several hours trying to find advice on a repeating timeline when I previewed my encore project I thought I’d post to help anyone in the same boat ….
    As many forums point out its a problem with the override…. what most places don’t tell you is that it’s not just the timelines and menus that have overrides (they should all say “Not Set” (unless you really know what you’re doing)) .. the actual buttons also have overrides and for some unknown reason occassionaly they set the override to something other than “Not Set” … to fix, open the menus tab and bring up the list of properties for the buttons and change to “Not Set”….
    hope this helps someone !
    Alan
    Joe Bowden replied 19 years ago 2 Members · 1 Reply
  • Joe Bowden
    September 18, 2007 at 2:03 pm
    Good advice (about not using overrides unless you understand what they do).
    However, only a user can set the override…Encore will not do this by itself.
