Activity › Forums › Apple Final Cut Pro › Timeline Question
  • Timeline Question
    Posted by Jordan Mena on December 23, 2013 at 5:33 pm
    I’ve noticed that when I use option+command+down on certain clips will either extend or shift a clip by a frame instead of just shifting the clip down to the primary storyline. Is this a bug or based on certain clip perimeters i’m not aware of?
    Thanks, J
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
    Jordan Mena replied 12 years, 9 months ago 2 Members · 3 Replies
  • Jordan Mena
    December 23, 2013 at 5:42 pm
    BTW, 10.0.9 🙂
    Los Angeles, CA
    jordanmena.com
  • Mark Morache
    December 23, 2013 at 7:52 pm
    I haven’t run into that. I’m wondering… are you mixing frame rates or anything? Maybe it’s trying to find the next closest frame.
    It’s easy enough to adjust afterwards, it should work.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Jordan Mena
    December 23, 2013 at 8:55 pm
    Frame rate is all the same. The reason I’m asking is it ripples the timeline and for promo work a :30 is a :30. Easy enough to fix using the position tool. Just thought i’d ask.
    Los Angeles, CA
    jordanmena.com
