Activity › Forums › Adobe Premiere Pro › Timeline not rendering
  • Timeline not rendering
    Posted by Thomas Pashko on November 20, 2011 at 8:16 am
    I’m fairly new to Premiere, so any assistance would be much appreciated.
    I’m working on a project in which I’ve had to Scale to Frame Size for all of my clips since I shot in a higher resolution than I’m editing in. Therefore I’ve had to render my timeline every time I add a new clip. I haven’t had any problems with this until around the 1:45 mark. But for some reason the clip starting at this point won’t render. When I render my work area, it just jumps to the beginning of my sequence and begins playing it instantly, the way it would after rendering has finished. For some reason, this last clip isn’t rendering. Any ideas why, and how I can fix this? Much appreciated.
    Paul Neumann replied 14 years, 10 months ago 3 Members · 2 Replies
  • Ann Bens
    November 20, 2011 at 5:19 pm
    Reduce the stills to frame size with e.g. Photoshop, see if that helps.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Paul Neumann
    November 21, 2011 at 3:21 am
    So why don’t you just edit at the resolution you shot at and output to whatever resolution you need?
