Activity Forums Apple Final Cut Pro Legacy Timeline Not Allowing stereo from sources
  • Timeline Not Allowing stereo from sources
    Posted by Max Carlson on August 12, 2010 at 5:01 pm
    I have a sequence that is not showing me both channels on a stereo music clip that I have so I can’t insert it into the sequence properly. It only sees a2, but not a1… But other sequences can see both a1 + a2…
    Anyone know why this is? Is there some sort of mono-lock I’m not aware of?
    Here’s an example pic, as you can see it is only showing a2, but not a1…
    https://www.maxcarlsonfilms.com/old/example.jpg
    Max Carlson replied 16 years ago 3 Members · 4 Replies
  • Jerry Hofmann
    August 12, 2010 at 5:20 pm
    You sure the clip has both tracks? You see them in the Viewer? What format is this clip, an aif or?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Aaron Neitz
    August 12, 2010 at 5:21 pm
    You A1 is probably hidden WAY down below target A18.
    Try clicking around in the Source area and see if you can get it to pop up. Or insert audio tracks till you find it and drag it back up.
  • Jerry Hofmann
    August 12, 2010 at 5:22 pm
    Good suggestion… you can also right click on a destination track to set which source track will go to it.
    Jerry
  • Max Carlson
    August 12, 2010 at 5:27 pm
    Hmm, I fixed it. I’m not sure why this occurs but if you click in the area near a2, you can select “reset panel”, and this popped a1 right back up… I’m not sure where it was hiding.
